Asus 1015E-DS03 Screen Replacement
  1. Asus 1015E-DS03 Screen Replacement, Battery: step 1, image 1 of 1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Screen Replacement: step 2, image 1 of 1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Screen Replacement: step 3, image 1 of 1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Screen Replacement: step 4, image 1 of 1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Screen Replacement, Front Screen Case: step 5, image 1 of 1
    • Push up on the back of the tabs that cover the hinges connecting the screen to the base of the laptop.
    • While pushing up on the back of the tabs, insert the spudger into the opening created from pushing on the tabs until the tab detaches.
  6. Asus 1015E-DS03 Screen Replacement: step 6, image 1 of 2 Asus 1015E-DS03 Screen Replacement: step 6, image 2 of 2
    • Once the case has been separated from the laptop, pull the case off completely, using the plastic opening tool or your fingers.
    • You will hear popping noises which are to be expected.
  7. Asus 1015E-DS03 Screen Replacement: step 7, image 1 of 1
    • When the screen case has been successfully removed, the laptop should resemble the photo shown here.
  8. Asus 1015E-DS03 Screen Replacement, Screen: step 8, image 1 of 1
    • Unscrew the 3 mm screws (4) using a #0 Phillips head screwdriver.
  9. Asus 1015E-DS03 Screen Replacement: step 9, image 1 of 2 Asus 1015E-DS03 Screen Replacement: step 9, image 2 of 2
    • Remove the screen.
    • Be careful removing the screen, as the left side is still connected to the computer.
  10. Asus 1015E-DS03 Screen Replacement: step 10, image 1 of 2 Asus 1015E-DS03 Screen Replacement: step 10, image 2 of 2
    • Remove the wire that is glued to the back of the screen with your fingers.
    • Remove the tape covering the connection port.
  11. Asus 1015E-DS03 Screen Replacement: step 11, image 1 of 1
    • Separate the screen from the computer by gently pulling it out.
  12. Asus 1015E-DS03 Screen Replacement: step 12, image 1 of 1
    • Upon removal, the computer should look like this picture.
Becca Day
297 Reputation
2 Guides authored
Clemson, Team 7-4, Benson Spring 2016 Member of Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 Members
7 Guides authored
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 14
All Time: 604
