Shop the Holiday Gift Guide
Astrolux BL03 Disassembly
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
86
All Time:
716
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide is to help you disassembly Astrolux BL013light. If this product does not charge, make sure that you are using original charging cable - not all cables work!
    1. Astrolux BL03 Disassembly, Flashlight: step 1, image 1 of 3 Astrolux BL03 Disassembly, Flashlight: step 1, image 2 of 3 Astrolux BL03 Disassembly, Flashlight: step 1, image 3 of 3
      • Both front cover (LEDs) and back cover (charging) can be pulled from the frame. Start with the back cover. You need to pry on the casing to let it go. Do not remove the front cover yet.
      • After removing back cover, you have access to the charging port. You can pull it and it comes right off
      • After that, you have access to the batteries which can be pulled. If you pull the batteries before disconnecting LEDs, you will break the cable
      • If you decide to remove the battery, you should pull leds first and unsolder batteries from it. Both removing the battery and leds is very difficult and is not recommended
      Ask FixBot
Marek D
73 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 86
All Time: 716
