Astro A40 TR Speakers Replacement
  1. Astro A40 TR Speakers Replacement, Speakers: step 1, image 1 of 2 Astro A40 TR Speakers Replacement, Speakers: step 1, image 2 of 2
    • To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
  2. Astro A40 TR Speakers Replacement: step 2, image 1 of 3 Astro A40 TR Speakers Replacement: step 2, image 2 of 3 Astro A40 TR Speakers Replacement: step 2, image 3 of 3
    • Remove the dust cover located on the speaker. Use the corner of the spudger to peel underneath the cover until you can lift it by hand. The cover is held onto the device with adhesive and should be removed slowly.
  3. Astro A40 TR Speakers Replacement: step 3, image 1 of 2 Astro A40 TR Speakers Replacement: step 3, image 2 of 2
    • Take off the front cover by removing the four screws located in a square formation on the surface of the device. Use the J00 Philips driver listed in the device page.
  4. Astro A40 TR Speakers Replacement: step 4, image 1 of 2 Astro A40 TR Speakers Replacement: step 4, image 2 of 2
    • Locate the three small screws under the speaker. Use the J00 Philips Driver to remove them.
  5. Astro A40 TR Speakers Replacement: step 5, image 1 of 2 Astro A40 TR Speakers Replacement: step 5, image 2 of 2
    • If your issue is asking for the complete replacement of the speaker or the motherboard, un-solder the old components and replace with new speaker by re-soldering.
Bhargav Makkapati
183 Reputation
1 Guide authored
UMass Dartmouth, Team 6-5, Martin Fall 2016 Member of UMass Dartmouth, Team 6-5, Martin Fall 2016
UMASSD-MARTIN-F16S6G5
3 Members
10 Guides authored
Past 24 Hours: 3
Past 7 Days: 18
Past 30 Days: 88
All Time: 9,291
