Aspire T180 Card Reader Replacement
    1. Aspire T180 Card Reader Replacement, Opening the case: step 1, image 1 of 3 Aspire T180 Card Reader Replacement, Opening the case: step 1, image 2 of 3 Aspire T180 Card Reader Replacement, Opening the case: step 1, image 3 of 3
      • Locate the 2 screws on the right side of the case’s rear panel, and remove them.
      • Locate the large metal tab just above the bottom screw, and push down on the tab while pulling the side panel towards the rear. The panel should slide off.
      Ask FixBot
    2. Aspire T180 Card Reader Replacement, Removing the hard drive: step 2, image 1 of 3 Aspire T180 Card Reader Replacement, Removing the hard drive: step 2, image 2 of 3 Aspire T180 Card Reader Replacement, Removing the hard drive: step 2, image 3 of 3
      Tool used on this step:
      Buy
      • Unless you have a long and thin pair of tweezers, the hard drive will need to be removed in order to unplug the card reader.
      • Start by pulling both cables off of the hard drive, and unplugging any cables on the motherboard that are in front of the drive.
      • Slide the green plastic tab to the left, and carefully pull out the hard drive. Gently set it down.
      Ask FixBot
    3. Aspire T180 Card Reader Replacement, Unplugging the card reader: step 3, image 1 of 2 Aspire T180 Card Reader Replacement, Unplugging the card reader: step 3, image 2 of 2
      • Locate the black connector on the bottom right corner of the motherboard.
      • Undo the cable tie holding the grey cables in front of it, and pull them out of the way.
      • Pull out the black connector. DO NOT PULL BY THE CABLE IF YOU PLAN TO REUSE THE CARD READER!
      Ask FixBot
    4. Aspire T180 Card Reader Replacement, Removing the card reader: step 4, image 1 of 3 Aspire T180 Card Reader Replacement, Removing the card reader: step 4, image 2 of 3 Aspire T180 Card Reader Replacement, Removing the card reader: step 4, image 3 of 3
      • Slide the highest green tab on the 3.5” bays to the right.
      • Push the card reader out halfway, and pull it out from the front.
      Ask FixBot
    5. Aspire T180 Card Reader Replacement, Inserting the new card reader: step 5, image 1 of 2 Aspire T180 Card Reader Replacement, Inserting the new card reader: step 5, image 2 of 2
      • Slide the new card reader in and push until it’s flush with the rest of the front panel.
      • Slide the green tab back to lock it in place.
      Ask FixBot
    6. Aspire T180 Card Reader Replacement, Connecting the card reader: step 6, image 1 of 3 Aspire T180 Card Reader Replacement, Connecting the card reader: step 6, image 2 of 3 Aspire T180 Card Reader Replacement, Connecting the card reader: step 6, image 3 of 3
      • Locate the missing hole on the connector and line it up with the missing pin on the motherboard.
      • Plug it in. Do not push too hard or the motherboard may be damaged.
      Ask FixBot
    7. Aspire T180 Card Reader Replacement, Reassembling the computer: step 7, image 1 of 1
      • Reinsert the hard drive and reconnect it. Remember to lock it in place by sliding the green tab.
      • Group all the cables together again, and secure them again with the cable tie.
      Ask FixBot
To finish reassembly, slide the side panel back on and reinsert both screws.
6 other people completed this guide.
Alex Smith
479 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 79
All Time: 2,090
