Arturia Microbrute Opening Procedure
    1. Arturia Microbrute Opening Procedure, Arturia Microbrute Opening Procedure: step 1, image 1 of 2 Arturia Microbrute Opening Procedure, Arturia Microbrute Opening Procedure: step 1, image 2 of 2
      • Switch off the Microbrute and make sure to disconnect any cables.
      • Don’t forget the mini patch bay on the top right.
      Ask FixBot
    2. Arturia Microbrute Opening Procedure: step 2, image 1 of 1
      • Flip the Microbrute over and put it on a soft surface to not damage the knobs and faders.
      • Use a screwdriver to remove the twelve Philips screws on the bottom plate.
      Ask FixBot
    3. Arturia Microbrute Opening Procedure: step 3, image 1 of 3 Arturia Microbrute Opening Procedure: step 3, image 2 of 3 Arturia Microbrute Opening Procedure: step 3, image 3 of 3
      • Put the Microbrute on its front edge and carefully tilt open the bottom plate including the keyboard.
      • Be aware of the ribbon cable connecting the keyboard to the PCB.
      • The cable should give you enough slack to put the top section over the keyboard section for better handling.
      Ask FixBot
    4. Arturia Microbrute Opening Procedure: step 4, image 1 of 1
      • Next, focus on the connector of the keyboard.
      Ask FixBot
    5. Arturia Microbrute Opening Procedure: step 5, image 1 of 3 Arturia Microbrute Opening Procedure: step 5, image 2 of 3 Arturia Microbrute Opening Procedure: step 5, image 3 of 3
      • Use a spudger to unlock the connector by pushing both left and right locking tabs tabs towards the cable.
      Ask FixBot
    6. Arturia Microbrute Opening Procedure: step 6, image 1 of 2 Arturia Microbrute Opening Procedure: step 6, image 2 of 2
      • Grab the ribbon cable with your fingers and pull it out of the connector.
      Ask FixBot
    7. Arturia Microbrute Opening Procedure: step 7, image 1 of 1
      • Now the Microbrute is open and the bottom plate with the keyboard is separated from the rest of the device.
      Ask FixBot
Tobias Isakeit
135,694 Reputation
189 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 18
Past 30 Days: 62
All Time: 626
