ARC-914SBD Push Button Interface Replacement
  1. ARC-914SBD Push Button Interface Replacement, Lid: step 1, image 1 of 2 ARC-914SBD Push Button Interface Replacement, Lid: step 1, image 2 of 2
    • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
  2. ARC-914SBD Push Button Interface Replacement: step 2, image 1 of 1
    • Once the condensation catcher has been removed, set it aside for reassembly later.
    • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
  3. ARC-914SBD Push Button Interface Replacement: step 3, image 1 of 2 ARC-914SBD Push Button Interface Replacement: step 3, image 2 of 2
    • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. ARC-914SBD Push Button Interface Replacement: step 4, image 1 of 3 ARC-914SBD Push Button Interface Replacement: step 4, image 2 of 3 ARC-914SBD Push Button Interface Replacement: step 4, image 3 of 3
    • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
  5. ARC-914SBD Push Button Interface Replacement, Push Button Interface: step 5, image 1 of 2 ARC-914SBD Push Button Interface Replacement, Push Button Interface: step 5, image 2 of 2
    • Locate the piece on the black plastic trim that is opposite from where the hinges were. Carefully, pry the bottom edge of this piece outward (away from the stainless steel side) about 1/4 inch to pull the tab out of it's hole. Once the bottom is pried out a bit, the tab can be seen from the bottom. Press up on the tab with a screwdriver.
  6. ARC-914SBD Push Button Interface Replacement: step 6, image 1 of 2 ARC-914SBD Push Button Interface Replacement: step 6, image 2 of 2
    • Next, you must remove the upper black trim which is connected to the inside liner with tabs. To do this you must hold the interior walls still, while rotating the trim so that the tabs line up with the slots. (tabs cannot be seen at this point, pics are to give you an idea of what you cannot see inside the device)
  7. ARC-914SBD Push Button Interface Replacement: step 7, image 1 of 2 ARC-914SBD Push Button Interface Replacement: step 7, image 2 of 2
    • Using a Phillips head screwdriver, size PH2, remove screws from the control module to expose wired connections.
  8. ARC-914SBD Push Button Interface Replacement: step 8, image 1 of 1
    • Unplug the interface from control module.
  9. ARC-914SBD Push Button Interface Replacement: step 9, image 1 of 2 ARC-914SBD Push Button Interface Replacement: step 9, image 2 of 2
    • Remove the two screws holding the cardboard cover over the Interface using a Phillips head screwdriver, size PH2.
  10. ARC-914SBD Push Button Interface Replacement: step 10, image 1 of 2 ARC-914SBD Push Button Interface Replacement: step 10, image 2 of 2
    • Using a Phillips head screwdriver, size PH2, remove the four screws holding the interface in place.
Brandon Nieves
956 Reputation
8 Guides authored
USF Tampa, Team 2-3, Sullivan Fall 2015 Member of USF Tampa, Team 2-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G3
3 Members
8 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 15
All Time: 488
