Introduction
If the spotlight on your Arlo Ultra 2 is no longer functioning then you most likely need to replace the spotlight component. A spotlight that is properly working will shine when triggered. If you are noticing that there is no light, then you should replace the spotlight. Additionally you will want to check the troubleshooting page for the Arlo Ultra 2.
Press the button on the bottom of the camera to release the housing.
Pull the white housing off the camera.
Use a Phillips #0 screwdriver to remove the four 20.0 mm screws from the battery cavity.
2 other people completed this guide.
3 Guide Comments
Where can I buy a new spotlight for this camera?
Thanks a lot. Took the LED from an old dead Ultra camera and it worked flawlessly.
