Aquaris M5 Front Camera Replacement
  1. Aquaris M5 Front Camera Replacement, Back Cover: step 1, image 1 of 2 Aquaris M5 Front Camera Replacement, Back Cover: step 1, image 2 of 2
    • Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
    • Between the 2 SIM card slots is a good place to start.
    • Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
  2. Aquaris M5 Front Camera Replacement: step 2, image 1 of 2 Aquaris M5 Front Camera Replacement: step 2, image 2 of 2
    • Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
    • Slide around the corner and along the top edge, to also disconnect these clips.
  3. Aquaris M5 Front Camera Replacement: step 3, image 1 of 3 Aquaris M5 Front Camera Replacement: step 3, image 2 of 3 Aquaris M5 Front Camera Replacement: step 3, image 3 of 3
    • Be careful not to bend the back cover too hard to prevent some of the clips breaking.
    • Grab the back cover by the loosened edge.
    • Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
    • Take off the back cover.
  4. Aquaris M5 Front Camera Replacement, Battery: step 4, image 1 of 1
    • Damaging the liquid indicator sticker, on the middle most screw, will void the warranty of the phone.
    • Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
    • Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
  5. Aquaris M5 Front Camera Replacement: step 5, image 1 of 3 Aquaris M5 Front Camera Replacement: step 5, image 2 of 3 Aquaris M5 Front Camera Replacement: step 5, image 3 of 3
    • Insert the flat side of a spudger between the mainboard shield and the frame of the phone.
    • Twist the spudger to lift up the mainboard shield.
    • Remove the mainboard shield from the phone.
  6. Aquaris M5 Front Camera Replacement: step 6, image 1 of 2 Aquaris M5 Front Camera Replacement: step 6, image 2 of 2
    • Use a spudger to disconnect the battery's flex cable from the mainboard.
    • Pull of the sticker on the bottom side of the battery.
    • Grab the sticker and lift it up to take the battery out of the phone.
  7. Aquaris M5 Front Camera Replacement, Front Camera: step 7, image 1 of 3 Aquaris M5 Front Camera Replacement, Front Camera: step 7, image 2 of 3 Aquaris M5 Front Camera Replacement, Front Camera: step 7, image 3 of 3
    • FPC Connectors can break easily, be very careful.
    • Use an opening tool or your finger nail to open the FPC connector.
    • Disconnect the FPC connector cable.
    • Use the tip of a spudger to leverage the camera out of its housing.
    • Remove the front camera.
Theo Mat
12,782 Reputation
14 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 13
All Time: 235
