Introduction
Use this guide to replace the daughterboard of your bq Aquaris M5.
Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
Slide the opening tool back to the top of the phone, to disconnect all the clips on the edge.
Slide around the corner and along the top edge, to also disconnect these clips.
Grab the back cover by the loosened edge.
Gently bend and twist the flexible back cover a bit to disconnect the remaining clips.
Take off the back cover.
Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
Insert the flat side of a spudger between the mainboard shield and the frame of the phone.
Twist the spudger to lift up the mainboard shield.
Remove the mainboard shield from the phone.
Use a spudger to disconnect the battery's flex cable from the mainboard.
Pull of the sticker on the bottom side of the battery.
Grab the sticker and lift it up to take the battery out of the phone.
Take out the seven 4mm Phillips #00 screws, holding the loud speaker unit to the mid frame of the phone.
Insert the flat side of a spudger into the gap on the right side of the loud speaker.
Lever the loud speaker up with the spudger.
Grab the loud speaker and take it out of the phone.
Use tweezers to disconnect the antenna cable from the daughterboard.
Unscrew the black Phillips #00 screw, that holds the power and volume buttons in place.
Use the flat end of a spudger to disconnect the flex cable from the mainboard.
Grasp the flex cable by the connector and carefully peel it off.
Use a spudger to lever out the daughterboard.
Remove the daughterboard.
