Apple TV 1st Generation Power Supply Replacement
  1. Apple TV 1st Generation Power Supply Replacement, Lower Case: step 1, image 1 of 1
    • Flip the Apple TV over so that the bottom of the unit is facing up.
    • You need to remove the rubber base to get access to the screws.
    • Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
    • The rubber base will be hot after heating, take extreme caution while proceeding to avoid personal injury.
    • While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
    • The rubber base can tear if the adhesive hasn't been softened enough.
    • Repeat the procedure described above until the rubber base has been completely removed.
  2. Apple TV 1st Generation Power Supply Replacement: step 2, image 1 of 1
    • Remove the four T10 Torx screws that secure the lower case to the upper case.
  3. Apple TV 1st Generation Power Supply Replacement: step 3, image 1 of 1
    • Carefully lift the lower case from the upper case enough to allow access to the internals of the Apple TV.
    • Be aware that the hard drive is physically attached to the lower case and that a ribbon cable runs from the drive to the logic board in the upper case.
  4. Apple TV 1st Generation Power Supply Replacement: step 4, image 1 of 2 Apple TV 1st Generation Power Supply Replacement: step 4, image 2 of 2
    • Carefully pull the hard drive data cable straight up from its socket on the logic board.
    • During reassembly, make sure the hard drive data cable is firmly seated in its socket on the logic board; otherwise, during boot-up you will see a flashing question mark "?".
  5. Apple TV 1st Generation Power Supply Replacement, AirPort Card: step 5, image 1 of 1
    • Pry the AirPort antenna cables straight up from their sockets on the logic board.
  6. Apple TV 1st Generation Power Supply Replacement: step 6, image 1 of 1
    • Remove the single T8 Torx screw securing the AirPort card to the logic board.
  7. Apple TV 1st Generation Power Supply Replacement: step 7, image 1 of 1
    • Cautiously lift the AirPort card and pull it straight away. Slide it from its socket on the logic board.
  8. Apple TV 1st Generation Power Supply Replacement, Power Supply: step 8, image 1 of 1
    • Disconnect the power cable straight up from its socket on the logic board.
    • There is a release tab that must be pushed inwards in conjunction with pulling to release the power cable
    • Make sure to pull the connector straight up from its socket and not toward the face of the logic board.
  9. Apple TV 1st Generation Power Supply Replacement: step 9, image 1 of 1
    • Remove the following three screws securing the power supply to the upper case:
    • One 4.8 mm T8 Torx screw
    • Two 5.8 mm T8 Torx screws
  10. Apple TV 1st Generation Power Supply Replacement: step 10, image 1 of 2 Apple TV 1st Generation Power Supply Replacement: step 10, image 2 of 2
    • Use your finger to push and dislodge the AC power connector inwards, towards the power supply.
    • This should pop out easily.
  11. Apple TV 1st Generation Power Supply Replacement: step 11, image 1 of 1
    • Power supply remains.
Celerityblur
154 Reputation
2 Guides authored
Cal Poly, Team 18-5, Maness Fall 2009 Member of Cal Poly, Team 18-5, Maness Fall 2009
CPSU-MANESS-F09S18G5
5 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 21,394
