Repairing Apple Studio Display M7649 Panels
  1. Repairing Apple Studio Display M7649 Panels, Stand: step 1, image 1 of 2 Repairing Apple Studio Display M7649 Panels, Stand: step 1, image 2 of 2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Repairing Apple Studio Display M7649 Panels, Panels: step 2, image 1 of 1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
    • These screws require the use of a metric allen wrench of the 2.5 size
  3. Repairing Apple Studio Display M7649 Panels: step 4, image 1 of 1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Repairing Apple Studio Display M7649 Panels: step 5, image 1 of 1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
Alan Truong
566 Reputation
3 Guides authored
Cal Poly, Team 3-20, Maness Winter 2010 Member of Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Members
15 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 24
All Time: 3,701
