Repairing Apple Studio Display M7649 ADC Cable
  1. Repairing Apple Studio Display M7649 ADC Cable, Stand: step 1, image 1 of 2 Repairing Apple Studio Display M7649 ADC Cable, Stand: step 1, image 2 of 2
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Repairing Apple Studio Display M7649 ADC Cable, Panels: step 2, image 1 of 1
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Repairing Apple Studio Display M7649 ADC Cable: step 3, image 1 of 1
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Repairing Apple Studio Display M7649 ADC Cable: step 4, image 1 of 1
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. Repairing Apple Studio Display M7649 ADC Cable, Metal EMI Shield: step 5, image 1 of 1
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Repairing Apple Studio Display M7649 ADC Cable: step 6, image 1 of 1
    • Now locate and remove the lone Phillips screw holding the EMI shield to the display
  7. Repairing Apple Studio Display M7649 ADC Cable: step 7, image 1 of 2 Repairing Apple Studio Display M7649 ADC Cable: step 7, image 2 of 2
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  8. Repairing Apple Studio Display M7649 ADC Cable, USB Port: step 8, image 1 of 1
    • To remove the USB port, remove these four screws holding down the port and metal brackets.
    • There may be a zip tie you need to cut that is attaching the USB unit to the display
  9. Repairing Apple Studio Display M7649 ADC Cable: step 9, image 1 of 1
    • Remove the cable from the logic board that is connecting the USB port.
  10. Repairing Apple Studio Display M7649 ADC Cable: step 10, image 1 of 1
    • Remove the USB port
  11. Repairing Apple Studio Display M7649 ADC Cable, ADC Cable: step 11, image 1 of 1
    • Remove these four screws holding down the base of the swing arm to the display and remove it
  12. Repairing Apple Studio Display M7649 ADC Cable: step 12, image 1 of 1
    • Remove the four screws holding down the ADC cable to the display
  13. Repairing Apple Studio Display M7649 ADC Cable: step 13, image 1 of 1
    • Remove the three connections that connects the ADC assembly to the logic board and screen
  14. Repairing Apple Studio Display M7649 ADC Cable: step 14, image 1 of 1
    • Remove and replace the ADC cable assembly.
Andrew Tsao
186 Reputation
5 Guides authored
Cal Poly, Team 3-20, Maness Winter 2010 Member of Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 Members
15 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 22
All Time: 2,809
