Repairing Apple Studio Display M2454 Main Computer Cable
  1. Repairing Apple Studio Display M2454 Main Computer Cable, Main Computer Cable: step 1, image 1 of 1
    • First, the back panel needs to be removed to access the cable connectors.
    • Locate the three 2mm hex screws located on the top of the stand and remove them.
    • Now locate and remove the four 2mm hex screws on the corners of the back panel.
    • Now remove the back panels while pulling the cable through them without damaging either part.
  2. Repairing Apple Studio Display M2454 Main Computer Cable: step 2, image 1 of 1
    • Remove the metal back plate by using the #2 philips head screwdriver and removing the top screw.
    • Now remove the two other philips screws located below the cable with the philips head screwdriver.
    • With all the screws removed, push the metal plate towards the bottom of the monitor to release the clips holding it to the monitor.
    • Pull the metal plate away.
  3. Repairing Apple Studio Display M2454 Main Computer Cable: step 3, image 1 of 1
    • Locate and remove the four #2 phillips screws located on the corners of the stand bracket, using the phillips head screwdriver.
    • Pull bracket away from monitor.
  4. Repairing Apple Studio Display M2454 Main Computer Cable: step 4, image 1 of 1
    • Remove the cable hold-down with #2 phillips head screwdriver.
  5. Repairing Apple Studio Display M2454 Main Computer Cable: step 5, image 1 of 1
    • Remove the screw at the bottom of the plastic bracket, using #2 phillips head screwdriver.
    • Pull the plastic bracket free.
    • Note the plastic pegs lining the bracket up with the monitor.
  6. Repairing Apple Studio Display M2454 Main Computer Cable: step 6, image 1 of 1
    • Remove tape holding down the white connector to the LCD main board.
  7. Repairing Apple Studio Display M2454 Main Computer Cable: step 7, image 1 of 1
    • With tape removed, the connections on the LCD main board can be disconnected.
    • First, remove the single hold-down using the philips head screwdriver.
    • Now locate the three connections the main cable makes with the monitor. Two are on the LCD Main Board and one other to the side.
    • Disconnect the white connector to the LCD main board by gently lifting tab with small pry tool and pulling out.
    • The tabs can easily break off, be extra careful
    • Disconnect the black connector to the LCD main board by pressing the tab and pulling out.
  8. Repairing Apple Studio Display M2454 Main Computer Cable: step 8, image 1 of 1
    • Now remove the connection not on the LCD Main Board by pulling back the tape holding the wires down first.
    • Remove the connector by hand.
  9. Repairing Apple Studio Display M2454 Main Computer Cable: step 9, image 1 of 1
    • Finally, the main cable can be replaced by pulling the old cable away and repeating the previous steps in reverse with a new, working main cable.
Dylan Perry
177 Reputation
5 Guides authored
Cal Poly, Team 13-27, Maness Winter 2010 Member of Cal Poly, Team 13-27, Maness Winter 2010
CPSU-MANESS-W10S13G27
4 Members
9 Guides authored
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 27
All Time: 5,631
