Apple Powerbook 5300 Memory Replacement
  1. Apple Powerbook 5300 Memory Replacement, Battery: step 1, image 1 of 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Memory Replacement, Keyboard: step 2, image 1 of 1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Memory Replacement: step 3, image 1 of 1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
  4. Apple Powerbook 5300 Memory Replacement, Memory: step 4, image 1 of 1
    • Pull up on the large green memory chip on the left side of the laptop. It will simply lift out.
Scott
155 Reputation
5 Guides authored
Cal Poly, Team 25-30, Garner Spring 2011 Member of Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 Members
6 Guides authored
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 11
All Time: 2,373
