Installing Apple PowerBook G3 400 Keyboard
  1. Installing Apple PowerBook G3 400 Keyboard, Keyboard: step 1, image 1 of 1
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
  2. Installing Apple PowerBook G3 400 Keyboard: step 2, image 1 of 1
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
  3. Installing Apple PowerBook G3 400 Keyboard: step 3, image 1 of 1
    • Your computer should look approximately like this.
Byron Hoefer
70 Reputation
2 Guides authored
Cal Poly, Team 4-2, Regan Spring 2011 Member of Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 Members
6 Guides authored
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,774
