Toshiba Satellite E45DW-C4210 Battery Replacement
    1. Toshiba Satellite E45DW-C4210  Battery  Replacement, Battery: step 1, image 1 of 1
      • Using a Phillips #0 screwdriver, remove all nine of the screws along the outside of the bottom of the laptop.
      Ask FixBot
    2. Toshiba Satellite E45DW-C4210  Battery  Replacement: step 2, image 1 of 3 Toshiba Satellite E45DW-C4210  Battery  Replacement: step 2, image 2 of 3 Toshiba Satellite E45DW-C4210  Battery  Replacement: step 2, image 3 of 3
      • Using your fingers, gently loosen the outside edge of the laptop.
      • Unsnap the bottom of the case from the computer by pulling each side apart in the middle of the computer.
      Ask FixBot
    3. Toshiba Satellite E45DW-C4210  Battery  Replacement: step 3, image 1 of 2 Toshiba Satellite E45DW-C4210  Battery  Replacement: step 3, image 2 of 2
      • Pull up the black strip of tape.
      Ask FixBot
    4. Toshiba Satellite E45DW-C4210  Battery  Replacement: step 4, image 1 of 1
      • Using your pointer finger and thumb grab the cords where they connect to the plug.
      • Gently pull the battery attachment from the laptop.
      Ask FixBot
    5. Toshiba Satellite E45DW-C4210  Battery  Replacement: step 5, image 1 of 2 Toshiba Satellite E45DW-C4210  Battery  Replacement: step 5, image 2 of 2
      • Using the Phillips #0 screwdriver, unscrew each of the four screws holding the battery in place.
      Ask FixBot
    6. Toshiba Satellite E45DW-C4210  Battery  Replacement: step 6, image 1 of 1
      • Lift and remove the battery from the device.
      Ask FixBot
2 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 16
Past 30 Days: 71
All Time: 2,479
