Installing Apple IIc Power Converter
  1. Installing Apple IIc Power Converter, Disassembling Apple IIc Cover: step 1, image 1 of 2 Installing Apple IIc Power Converter, Disassembling Apple IIc Cover: step 1, image 2 of 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Installing Apple IIc Power Converter: step 2, image 1 of 2 Installing Apple IIc Power Converter: step 2, image 2 of 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Installing Apple IIc Power Converter: step 3, image 1 of 2 Installing Apple IIc Power Converter: step 3, image 2 of 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Installing Apple IIc Power Converter: step 4, image 1 of 2 Installing Apple IIc Power Converter: step 4, image 2 of 2
    • Lift the handle straight up to remove.
  5. Installing Apple IIc Power Converter, Power Converter: step 5, image 1 of 1
    • Remove the two 7.7mm length Phillips screws that secure the power converter.
  6. Installing Apple IIc Power Converter: step 6, image 1 of 2 Installing Apple IIc Power Converter: step 6, image 2 of 2
    • Grab the back of the power supply and pull out while lifting up so that it will clear the other components.
    • The power supply can be difficult to remove so be careful not to bend or damage any nearby components while you pull out the power supply.
Josiah
658 Reputation
3 Guides authored
Cal Poly, Team 21-23, Maness Fall 2011 Member of Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 Members
13 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 23
All Time: 4,224
