Introduction
The three WiFi antenna are very fragile and sensitive. Be very careful when removing and replacing them, as touching the replacement antenna can cause them to not function at peak efficiency. The old antenna do not require the same care, though you should avoid bending or forcing to remove the antenna because they could snap and ruin the device. Also be careful with the metal attached to the antenna can bend and cause the metal casing to not fit back together with the other pieces.
Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
Remove logic board and metal casing from outer case by prying from one side using a spudger.
Carefully push back the three metal tabs with your fingers on the sides of metal case.
Unscrew the 5mm #00 screws from each of the three antennas located on the sides of the metal casing.
Pull away antennas from metal case.
Pull up the less visible silver tape that holds the antenna cords in place at the ends of the device using your fingers.
Remove clear yellow tape that holds the cords to the outer casing in the same manner.
