Apple AirPort Extreme Model A1143 Case Replacement
  1. Apple AirPort Extreme Model A1143 Case Replacement, Back Pad: step 1, image 1 of 1
    • The back pad is held in with glue so use caution when removing to prevent tearing. Low heat may be used to help remove the pad.
    • Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
  2. Apple AirPort Extreme Model A1143 Case Replacement, Back Cover: step 2, image 1 of 1
    • After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
  3. Apple AirPort Extreme Model A1143 Case Replacement: step 3, image 1 of 1
    • Lift up the back case from the perforated edge to remove it.
  4. Apple AirPort Extreme Model A1143 Case Replacement, Remove from Case: step 4, image 1 of 1
    • Remove logic board and metal casing from outer case by prying from one side using a spudger.
Zak
616 Reputation
4 Guides authored
USF Tampa, Team 12-4, Blackwell Fall 2014 Member of USF Tampa, Team 12-4, Blackwell Fall 2014
USFT-BLACKWELL-F14S12G4
5 Members
10 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 3,106
