Apple AirPort Extreme Model A1034 Antenna Replacement
  1. Apple AirPort Extreme Model A1034 Antenna Replacement, Outer Case: step 1, image 1 of 1
    • Remove the three 14.3mm T7 Torx screws from the bottom of AirPort.
  2. Apple AirPort Extreme Model A1034 Antenna Replacement: step 2, image 1 of 1
    • Remove the 5.1mm Phillips screw from the bottom of the AirPort. This screw is located under the identification sticker. You will have to remove the sticker or make a hole to remove it.
  3. Apple AirPort Extreme Model A1034 Antenna Replacement: step 3, image 1 of 2 Apple AirPort Extreme Model A1034 Antenna Replacement: step 3, image 2 of 2
    • Lift the bottom and top casing straight apart and then lift metal casing straight up from the bottom plastic casing.
  4. Apple AirPort Extreme Model A1034 Antenna Replacement: step 4, image 1 of 1
    • Unplug the black connector on the top of the metal casing by gently pulling horizontally.
  5. Apple AirPort Extreme Model A1034 Antenna Replacement, Antenna: step 5, image 1 of 1
    • Remove the two 4mm phillips screws to remove antenna.
  6. Apple AirPort Extreme Model A1034 Antenna Replacement: step 6, image 1 of 1
    • The circuit board connected to the antenna is attached to the metal case with foam adhesive.
    • Gently peel or cut the foam holding the circuit board with a knife and remove it from the AirPort.
Michael Garcia
411 Reputation
5 Guides authored
Cal Poly, Team 17-15, Regan Fall 2011 Member of Cal Poly, Team 17-15, Regan Fall 2011
CPSU-REGAN-F11S17G15
3 Members
13 Guides authored
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 13
All Time: 4,681
