Apalus Digital Hair Straightening Brush Buttons Replacement
  1. Apalus Digital Hair Straightening Brush Buttons Replacement, Buttons on the side of the brush: step 1, image 1 of 1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Buttons Replacement: step 2, image 1 of 1
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush Buttons Replacement: step 3, image 1 of 1
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush Buttons Replacement: step 4, image 1 of 1
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush Buttons Replacement: step 5, image 1 of 1
    • Locate the three buttons on the bottom side of the circuit board.
  6. Apalus Digital Hair Straightening Brush Buttons Replacement: step 6, image 1 of 1
    • Each button is soldered in four places on the circuit board. Using the soldering tool, melt each of these four points and remove the dysfunctional buttons.
    • You may have to bend the dark red capacitor out of the way to reach the soldering points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Buttons Replacement: step 7, image 1 of 1
    • Now that the dysfunctional buttons are removed, use a soldering tool and solder to install the new buttons on the circuit board.
    • Solder at the same four points as when previously melting these points to remove the buttons.
Aaron Brysch
231 Reputation
2 Guides authored
IUPUI, Team S1-G3, Harley Fall 2017 Member of IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
3 Members
3 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 21
All Time: 659
