Anki Vector LCD Facial Display Replacement
  1. Anki Vector LCD Facial Display Replacement, LCD Facial Display: step 1, image 1 of 3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: step 1, image 2 of 3 Anki Vector LCD Facial Display Replacement, LCD Facial Display: step 1, image 3 of 3
    • Using the iFixit opening tool, insert the corner under Vector's golden side panel and lightly twist.
    • Repeat this step on the other side.
    • The panel should pop off without much force.
  2. Anki Vector LCD Facial Display Replacement: step 2, image 1 of 3 Anki Vector LCD Facial Display Replacement: step 2, image 2 of 3 Anki Vector LCD Facial Display Replacement: step 2, image 3 of 3
    • Insert the corner of the square end of the spudger under the side plate above the partially visible screw.
    • Lightly turn the spudger to separate the plate from Vector's head.
    • Work the spudger around the plate until it comes off.
    • Repeat this step on the the other side.
  3. Anki Vector LCD Facial Display Replacement: step 3, image 1 of 2 Anki Vector LCD Facial Display Replacement: step 3, image 2 of 2
    • Using a Phillips #0 screwdriver, unscrew the two 2 mm screws on the side of Vector's head.
    • Repeat this step on the opposite side.
  4. Anki Vector LCD Facial Display Replacement: step 4, image 1 of 2 Anki Vector LCD Facial Display Replacement: step 4, image 2 of 2
    • Pull apart Vector's head. It should separate down the middle.
    • Remove the screen protector by gently pulling it free from the two face halves.
  5. Anki Vector LCD Facial Display Replacement: step 5, image 1 of 3 Anki Vector LCD Facial Display Replacement: step 5, image 2 of 3 Anki Vector LCD Facial Display Replacement: step 5, image 3 of 3
    • Using your thumb and index finger, unplug the display from the plug in Vector's neck.
    • Pull the LCD and speaker assembly from Vector's head.
    • There is a very thin insulating rubber sheet located at the base of the screen. Be careful not to tear it when removing the display.
Shay Takei
1,570 Reputation
5 Guides authored
Cal Poly, Team S2-G6, Maness Spring 2019 Member of Cal Poly, Team S2-G6, Maness Spring 2019
CPSU-MANESS-S19S2G6
4 Members
10 Guides authored
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 77
All Time: 10,860
