Anker Soundcore Life Q20 Buttons Replacement
    1. Anker Soundcore Life Q20 Buttons Replacement, Ear Cushion: step 1, image 1 of 1
      • Choose the desired ear cushion to replace.
      • Orient the headphones so that the side of the ear cushion is accessible.
      Ask FixBot
    2. Anker Soundcore Life Q20 Buttons Replacement: step 2, image 1 of 2 Anker Soundcore Life Q20 Buttons Replacement: step 2, image 2 of 2
      • Wedge the iFixit opening tool into the groove where the ear cushion meets the base of the headphones.
      • Pry the ear cushion apart from the base.
      Ask FixBot
    3. Anker Soundcore Life Q20 Buttons Replacement: step 3, image 1 of 2 Anker Soundcore Life Q20 Buttons Replacement: step 3, image 2 of 2
      • Repeat step 2 in a rotation around the ear cushion until it is fully detached from the base.
      Ask FixBot
    1. Anker Soundcore Life Q20 Buttons Replacement, Battery: step 4, image 1 of 3 Anker Soundcore Life Q20 Buttons Replacement, Battery: step 4, image 2 of 3 Anker Soundcore Life Q20 Buttons Replacement, Battery: step 4, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the four 10 mm screws from the cover.
      • Remove the cover to expose the battery.
      Ask FixBot
    2. Anker Soundcore Life Q20 Buttons Replacement: step 5, image 1 of 1
      • Use your index finger to lift the battery and remove it from the base.
      • Desolder the battery from the board, following the instructions from the iFixit soldering guide: How To Solder and Desolder Connections
      Ask FixBot
    1. Anker Soundcore Life Q20 Buttons Replacement, Buttons: step 6, image 1 of 1
      • Using the Phillips #00 screwdriver, remove the two 7 mm screws from the green board.
      Ask FixBot
    2. Anker Soundcore Life Q20 Buttons Replacement: step 7, image 1 of 1
      • Press the buttons as usual to pop them out of the base.
      • Gently pull the remaining tabs inside the base to disconnect the buttons.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 56
All Time: 485
