Anker Soundcore Flare Mini Waterproof Outer Shell Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
15
Past 30 Days:
72
All Time:
1,253
Comments: 3
2 comments on steps, 1 guide comment.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Missing Steps
Oops! This guide is currently missing one or more important steps.
Introduction
Go to step 1 ↓
This guide will show you how to replace the waterproof outer shell on the Anker Soundcore Flare Mini A3167.
The waterproof outer shell protects the electronic components of the Anker Soundcore Flare Mini speaker.
Before starting the replacement, make sure the speaker is turned off and is unplugged from the power cord!
Tools
    1. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: step 1, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: step 1, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Bottom Cover: step 1, image 3 of 3
      Tool used on this step:
      Buy
      • The rubber cover of the speaker is glued down.
      • Use precision tweezers to peel the rubber cover off of the bottom of the speaker.
      Ask FixBot
    2. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 2, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 2, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 2, image 3 of 3
      • Remove six 10 mm screws holding the plastic cover in place using a Phillips #1 screwdriver.
      • Use your hand to pull the plastic cover off the bottom of the speaker.
      Ask FixBot
    1. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: step 3, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: step 3, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Motherboard: step 3, image 3 of 3
      • Remove the single 10 mm screw holding the motherboard in place using a Phillips #1 screwdriver.
      • Lift the motherboard up.
      • The motherboard is still attached to several wires underneath.
      Ask FixBot
    2. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 4, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 4, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 4, image 3 of 3
      Buy
      • Use precision tweezers to firmly grasp the five power connectors and detach them from the back of the motherboard.
      • When removing the power connectors, do not pull the wires themselves.
      • Remove the motherboard from the speaker.
      Ask FixBot
    1. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: step 5, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: step 5, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement, Waterproof Outer Shell: step 5, image 3 of 3
      • Remove the four 11 mm screws from the white plastic cover using a Phillips #1 screwdriver.
      • Remove the white plastic cover from the speaker.
      Ask FixBot
    2. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 6, image 1 of 2 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 6, image 2 of 2
      • Remove the other four 11 mm screws holding the outer shell in place with a Phillips #1 screwdriver.
      Ask FixBot
    3. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 7, image 1 of 1
      • Pull the charging port away from the side of the speaker.
      Ask FixBot
    4. Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 8, image 1 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 8, image 2 of 3 Anker Soundcore Flare Mini Waterproof Outer Shell Replacement: step 8, image 3 of 3
      • Use a spudger to loosen the cover from the inner components of the speaker.
      • Slide the cover completely off.
      • One wire will still be connected to the shell.
      Ask FixBot
1 Guide Comment
Where can I purchase the outer shell? Share link please
Arsam Sohail - Reply Share
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 72
All Time: 1,253
