Anker Soundcore 3 Battery Replacement
    1. Anker Soundcore 3 Battery Replacement, Battery: step 1, image 1 of 2 Anker Soundcore 3 Battery Replacement, Battery: step 1, image 2 of 2
      • Gently heat the perimeter of the device with a hairdryer to loosen the adhesive.
      • Insert a metal spudger in between the speaker's front grill and chassis.
      • Continuously pry around the edges of the casing; you should hear the glue start to separate from the front panel before the two parts separate.
      Ask FixBot
    2. Anker Soundcore 3 Battery Replacement: step 2, image 1 of 3 Anker Soundcore 3 Battery Replacement: step 2, image 2 of 3 Anker Soundcore 3 Battery Replacement: step 2, image 3 of 3
      • Remove 8 of the 10 mm screws from the speaker panel using a Phillips #0 screwdriver.
      • Using the metal spudger, gently pry at the outer-edges of the speaker to remove the rubber/plastic panel that sits above the motherboard.
      • Grip and disconnect the cable connector from both the rubber/plastic panel and the mainboard.
      Ask FixBot
    3. Anker Soundcore 3 Battery Replacement: step 3, image 1 of 2 Anker Soundcore 3 Battery Replacement: step 3, image 2 of 2
      • Remove the four 10 mm screws that secure the battery with a Phillips #00 screwdriver.
      • Firmly grasp the connector cable and gently pull up to remove it from the mainboard.
      • Remove the battery.
      Ask FixBot
1 Guide Comment
NIce, now what is the battery that can replace this one? what are the specification of the battery?
Tevin - Reply Share
Past 24 Hours: 3
Past 7 Days: 34
Past 30 Days: 156
All Time: 1,767
