Angry Miao Xmas Key Switch Replacement
    1. Angry Miao Xmas Key Switch Replacement, Key Switch: step 1, image 1 of 3 Angry Miao Xmas Key Switch Replacement, Key Switch: step 1, image 2 of 3 Angry Miao Xmas Key Switch Replacement, Key Switch: step 1, image 3 of 3
      • Facing the keyboard downwards, remove eight 26 mm screws holding the keyboard together.
      • Rotate the screws in a counterclockwise motion to unscrew.
      Ask FixBot
    2. Angry Miao Xmas Key Switch Replacement: step 2, image 1 of 1
      • Remove the 4 screws of the brass weight in the same counterclockwise motion as done in previous steps.
      Ask FixBot
    3. Angry Miao Xmas Key Switch Replacement: step 3, image 1 of 2 Angry Miao Xmas Key Switch Replacement: step 3, image 2 of 2
      • Carefully disconnect the brass battery from the top housing by removing the 3 cables.
      Ask FixBot
    4. Angry Miao Xmas Key Switch Replacement: step 4, image 1 of 3 Angry Miao Xmas Key Switch Replacement: step 4, image 2 of 3 Angry Miao Xmas Key Switch Replacement: step 4, image 3 of 3
      • When flipped upside down, the back of keyboard will look like this.
      • Remove the brass weight, then disconnect the keyboard PCB by removing the 2 ribbons from the latch holding it down.
      Ask FixBot
    5. Angry Miao Xmas Key Switch Replacement: step 5, image 1 of 1
      • Remove the 2 screws attached on top and take PCB kit out.
      Ask FixBot
    6. Angry Miao Xmas Key Switch Replacement: step 6, image 1 of 3 Angry Miao Xmas Key Switch Replacement: step 6, image 2 of 3 Angry Miao Xmas Key Switch Replacement: step 6, image 3 of 3
      • Remove the rest of the screws in the same way which will separate the plate, mute mount, and PCB.
      Ask FixBot
    7. Angry Miao Xmas Key Switch Replacement: step 7, image 1 of 3 Angry Miao Xmas Key Switch Replacement: step 7, image 2 of 3 Angry Miao Xmas Key Switch Replacement: step 7, image 3 of 3
      Tool used on this step:
      Buy
      • Clean the PCB.
      • Pull out the cover by using tweezers.
      Ask FixBot
    8. Angry Miao Xmas Key Switch Replacement: step 8, image 1 of 1
      • Install the new key switches by pressing on the PCB.
      Ask FixBot
Qiu Yunfan
169 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 18
Past 30 Days: 82
All Time: 612
