Introduction
The On/Off switch located on the front panel may become damaged and no longer function correctly. With a dysfunctional switch, you may not be able to get the shredder to operate.
Remove seven 11 mm Phillips #1 screws from the underside of the head unit.
Find the green control board that is located next to the shredding motor.
Remove two 11 mm Phillips #1 screws located on opposite sides of the control board.
Pull the front panel away from the shredding unit.
Locate the black On/Off switch attached to the front panel where the control board was once attached.
Squeeze the wings of the On/Off switch from the inside of the front panel to detach it from its slot in the panel.
