Amazon Kindle 8 Back Cover Replacement
    1. Amazon Kindle 8 Back Cover Replacement, Front Cover: step 1, image 1 of 2 Amazon Kindle 8 Back Cover Replacement, Front Cover: step 1, image 2 of 2
      • Insert the iFixit opening tool into any corner of the Kindle’s front cover.
      • Gently slide the tool along the edges and carefully separate the front cover from the inner front cover.
      • Keep even pressure to avoid any cracks.
      • Lift front cover once all clips are disengaged.
      • Lift the front cover gently so that it is not cracked.
      Ask FixBot
    2. Amazon Kindle 8 Back Cover Replacement: step 2, image 1 of 2 Amazon Kindle 8 Back Cover Replacement: step 2, image 2 of 2
      • Insert the spudger between the inner front cover and the screen.
      • Gently work your way around to loosen the inner front cover.
      • Carefully lift the inner front cover from the device.
      Ask FixBot
    1. Amazon Kindle 8 Back Cover Replacement, Motherboard: step 3, image 1 of 2 Amazon Kindle 8 Back Cover Replacement, Motherboard: step 3, image 2 of 2
      • Use a T4 Torx screwdriver to remove the seven 3 mm screws around the perimeter of the device.
      Ask FixBot
    2. Amazon Kindle 8 Back Cover Replacement: step 4, image 1 of 2 Amazon Kindle 8 Back Cover Replacement: step 4, image 2 of 2
      • Lift the screen and motherboard from the back cover.
      Ask FixBot
    1. Amazon Kindle 8 Back Cover Replacement, Back Cover: step 5, image 1 of 1
      • Separate the motherboard and the back cover.
      Ask FixBot
Repair didn’t go as planned? Try some basic troubleshooting or ask our Answers community for help.
Luke
456 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 6
Past 7 Days: 23
Past 30 Days: 59
All Time: 888
