Introduction
This guide takes you step by step through the process required to replace the batteries of the Amazon Fire TV Stick remote. This task is simple and should not take more than a few minutes. To complete this you will need a plastic opening tool and two new batteries. If you follow the easy steps you will successfully change the remote batteries in your Amazon fireTV stick.
Use the plastic opening tool to press into the seam between the remote and battery cover.
With the same tool to help pop the batteries out.
