Amazon Fire TV Remote Control Motherboard Replacement
  1. Amazon Fire TV Remote Control Motherboard Replacement, Batteries: step 1, image 1 of 2 Amazon Fire TV Remote Control Motherboard Replacement, Batteries: step 1, image 2 of 2
    • Turn the remote control over to show its back and place your index finger in the tab. Squeeze gently to open the battery cover.
    • Lift the battery cover up to expose the batteries.
  2. Amazon Fire TV Remote Control Motherboard Replacement: step 2, image 1 of 2 Amazon Fire TV Remote Control Motherboard Replacement: step 2, image 2 of 2
    • Use your index finger to push the battery back and lift up to remove the battery.
    • Repeat the procedure for the second battery.
  3. Amazon Fire TV Remote Control Motherboard Replacement, Remote control motherboard: step 3, image 1 of 2 Amazon Fire TV Remote Control Motherboard Replacement, Remote control motherboard: step 3, image 2 of 2
    • Locate the four 3.6 mm Phillips J#00 screws found under the back panel of the remote control and remove them.
  4. Amazon Fire TV Remote Control Motherboard Replacement: step 4, image 1 of 2 Amazon Fire TV Remote Control Motherboard Replacement: step 4, image 2 of 2
    • Locate the bottom of the remote control.
    • Place your thumb on the bottom part of the remote. Apply pressure as shown in the picture to release the back panel from the front of the case.
  5. Amazon Fire TV Remote Control Motherboard Replacement: step 5, image 1 of 2 Amazon Fire TV Remote Control Motherboard Replacement: step 5, image 2 of 2
    • Insert a plastic opening tool in the gap and apply some force to disconnect the two pieces away from each other.
    • Since there are two pins keeping the back of the case together with the motherboard, some force is needed to separate them.
  6. Amazon Fire TV Remote Control Motherboard Replacement: step 6, image 1 of 1
    • Unscrew the seven 2.4 mm Phillips J#00 screws that connect the motherboard to the case.
  7. Amazon Fire TV Remote Control Motherboard Replacement: step 7, image 1 of 1
    • Place the plastic opening tool or your fingernail in the gap at the top end and lift the motherboard.
Alejandro Franco Ceron
739 Reputation
3 Guides authored
USF Tampa, Team 16-3, Wollert Fall 2015 Member of USF Tampa, Team 16-3, Wollert Fall 2015
USFT-WOLLERT-F15S16G3
4 Members
16 Guides authored
Past 24 Hours: 4
Past 7 Days: 32
Past 30 Days: 205
All Time: 12,618
