Amazon Fire HD 8 Plus 12th Rear Case Replacement
    1. Amazon Fire HD 8 Plus 12th Rear Case Replacement, Rear Case: step 1, image 1 of 2 Amazon Fire HD 8 Plus 12th Rear Case Replacement, Rear Case: step 1, image 2 of 2
      • Unplug the charger, power down the device, and remove the SD card before beginning.
      • Insert an opening pick into the seam between the rear case and the screen assembly.
      • Slide the opening pick around the perimeter, prying periodically, until the screen assembly begins to release.
      • Insert an opening tool into the gap you created, and continue to pry periodically around the entire perimeter until the screen assembly fully releases.
      • Be patient and don't pry too hard in any specific place. Excessive force may cause damage to the device.
      Ask FixBot
    2. Amazon Fire HD 8 Plus 12th Rear Case Replacement: step 2, image 1 of 1
      • Remove the rear case.
      Ask FixBot
Connor Bassolino
25,914 Reputation
125 Guides authored
iFixit Member of iFixit
Staff
122 Members
72,303 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 19
Past 30 Days: 53
All Time: 440
