Introduction
Before you begin, make sure the device is off. The screen and digitizer will come off as one connected component.
Lift the screen and digitizer from the case.
Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
26 other people completed this guide.
16 Comments
Where can you get a replacement digitizer screen? My grandson dropped his a couple days ago & I don't want to spend another $200 for a new one.
I am seeing replacement screen/digitizers for these now on ebay. With a little searching around I found one direct ship from Hong Kong for $70US. Good Luck!
I can't seem the find a replacement screen for this specification anywhere
I need the the cable that goes to the sceen. As i changed out my battery, when i tried to carefully remove the zif connector, it broke off. Woe is me.
what best double sided tape for kindle hd 10 digitizer repair?
Cheaper to buy a new one and keep the broken one in the car or garage.
This is true. Going forward, I’d recommend getting the kid’s edition no matter what. It is a great insurance policy. Amazon honors their warranty nicely…
Does anybody know if the 2017 model uses the same screen and/or digitizer as the 2015 model?
This is what I’ve found online
That is only the glass, and not the LCD… This guide doesn’t include the steps to separate the glass from the LCD assembly…
This did not work for me. I wonder if it changed in newer models ? I pried it open on the side, then the whole back cover came off. It was impossible to separate the glass from the rest without breaking it all. Wonder what I did wrong.
Extremely simple and very well documented. Thank you for making the replacement less difficult. Just one question, how do you get the plastic tool to fit in between the screen and the frame? Mine wore out trying to scrape and push its way in there
Too bad the cost of the part is so high.
Anyone try using this screen in other projects? I am looking for an adapter for the ribbon cable to HDMI or DPSI
The right side with the power switch on top?
Sonny Shear - Reply
Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
Thanks!
Steve Ciciora - Reply
