Introduction
Use this guide to replace the motherboard in your Amazon Fire HD 10.
Lift the screen and digitizer from the case.
Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
Locate the power cable that links the battery to the motherboard.
Carefully unplug the battery power cable to disconnect the battery from the motherboard.
Battery removal is optional for the motherboard, but is a great addition to this guide for completeness.
Begin by locating the double sided pull tape locations.
Pull the black soft tabs to release the tape's adhesion.
Do this to all 4 tabs until the battery is completely free of adhesion to the device's backing.
Remove the two screws from front facing camera using the T5 Torx Screwdriver.
Remove the ten T5 Torx screws securing the motherboard to the case.
Before moving to the removal of the motherboard, there are VERY small and EXTREMELY breakable ZIF sockets for the power button and volume buttons. I didn't realize this and started to pull the motherboard out. Thankfully they disengaged but the flaps that lock them back in are nearly paper thin. Use caution, particularly when reinstalling and closing the ZIF sockets. Lastly the power button was lose in my deinstallation because I removed the screw. It's not necessary to remove that screw.
14 other people completed this guide.
6 Comments
Just for the record, my screws were T4, not T5.
what you left out is the speakers are they still attached to the motherboard you get 15 points
Is this the Kindle? Not the Tablet?
iI am tired of searching for T76N2B motherboard replacement. Any help will be much appreciated
The right side with the power switch on top?
Sonny Shear - Reply
Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
Thanks!
Steve Ciciora - Reply
