Introduction
You will need to use the screen replacement guide as a prerequisite.
Lift the screen and digitizer from the case.
Hi Beldenr! We happen to have a handy guide for a lot of different types of connectors, including ZIF connectors.
Remove the two screws from front facing camera using the T5 Torx Screwdriver.
The right side with the power switch on top?
Sonny Shear - Reply
Where is the right hand corner? Is it the corner nearest the USB connector? Farthest from USB connector?
Thanks!
Steve Ciciora - Reply
