Introduction
The Amazon Fire 5th generation uses a 2980 mAh rechargeable Lithium-ion Battery Pack. When replacing the battery pack, ensure that the proper safety and protective gear are used to avoid potential harm.
Holding the Fire firmly, wedge a plastic opening tool into the crease on the edge of the device.
Slowly work the plastic opening tool around the device until the entire back cover releases from the front of the device.
Carefully and slowly work a large plastic opening tool along the edge of the battery pack. Angle the tool to pry it up.
When you have successfully lifted the battery pack up on one side or corner, carefully wedge the opening tool under the pack about 1/2" and work around the rest of the sides.
I found a replacement battery at https://www.ebay.com/itm/372639534862?mk...
Worked like a charm. Started by the usb slot with it open as it was the easiest place to get a start.
23 other people completed this guide.
9 Comments
Where do you purchase the replacement battery (and what part number)?
Battery to buy right below!
Thanks for this guide Maximilian, and also for the link to purchase the battery, commenter Jorge! Those batteries seem to be pretty difficult to find online. Amazon definitely doesn’t make it easy to find them even on their own site, though they seem happy to sell a replacement fire… :)
Update: I had to do two of these, and it didn’t take me any longer than 10 minutes for either one of them. Easy peasy, thanks for the clear and concise guide.
If the battery connector comes off does it need soldering back on
@stash115 Are you talking about the connector attached to the wires that are on the battery or the connector on the circuit board of the Fire?
The black connector on the circuit board
Updated link to battery: (only $5usd)
A couple of details: 1. The connector is removed in a direction perpendicular to the plane of the board. I found that the gentle application of a knife blade on the side away from the wires, followed by moving the blade away from the board, will do the trick. 2. The adhesive is a 1/4” strip around the edges of the battery. There is no adhesive elsewhere.
