Amazon Echo Studio Light Board Replacement
    1. Amazon Echo Studio Light Board Replacement, Power Supply Board: step 1, image 1 of 3 Amazon Echo Studio Light Board Replacement, Power Supply Board: step 1, image 2 of 3 Amazon Echo Studio Light Board Replacement, Power Supply Board: step 1, image 3 of 3
      • Flip the device upside down.
      • Pry up the edge of the rubber base panel with a spudger, then pull the rest of it off by hand.
      Ask FixBot
    2. Amazon Echo Studio Light Board Replacement: step 2, image 1 of 3 Amazon Echo Studio Light Board Replacement: step 2, image 2 of 3 Amazon Echo Studio Light Board Replacement: step 2, image 3 of 3
      • Use a T15 Torx screwdriver to remove the nine 3.2 mm screws.
      • Use a Torx T10 screwdriver to remove the six 2.7 mm screws.
      • After removing the screws, gently lift the base off, with care not to damage any of the connected cables.
      Ask FixBot
    3. Amazon Echo Studio Light Board Replacement: step 3, image 1 of 3 Amazon Echo Studio Light Board Replacement: step 3, image 2 of 3 Amazon Echo Studio Light Board Replacement: step 3, image 3 of 3
      • Before fully removing the base, remove the three attached connectors.
      Ask FixBot
    4. Amazon Echo Studio Light Board Replacement: step 4, image 1 of 2 Amazon Echo Studio Light Board Replacement: step 4, image 2 of 2
      • Now unscrew the the single 10 mm Phillips screw.
      • Remove the power supply board.
      Ask FixBot
    1. Amazon Echo Studio Light Board Replacement, Subwoofer: step 5, image 1 of 1
      • Remove the two screws located across from each other on the outside of the plastic ring shown.
      • Remove the plastic outer ring that hugs the inside of the edges of the device.
      • This may require you to use a soft prying tool to separate it from the outer shell.
      Ask FixBot
    2. Amazon Echo Studio Light Board Replacement: step 6, image 1 of 3 Amazon Echo Studio Light Board Replacement: step 6, image 2 of 3 Amazon Echo Studio Light Board Replacement: step 6, image 3 of 3
      • Remove the two 2.7 mm screws with a T10 Torx screwdriver.
      • Once the screws are removed, take the power supply's baseplate out of the unit.
      • You may need to gently pry the subwoofer's air ports from the round slots In the side of the unit.
      Ask FixBot
    3. Amazon Echo Studio Light Board Replacement: step 7, image 1 of 2 Amazon Echo Studio Light Board Replacement: step 7, image 2 of 2
      • On the silver ring located on the outer edge of the plastic portion of the subwoofer, you will see four 2.7 mm screws. Use a Torx T10 screwdriver to remove them, in order to remove of the subwoofer.
      • Once the four screws have been removed, gently pull the subwoofer out as to not damage the wiring connecting the subwoofer to the main board inside the unit.
      • Follow the wires from the subwoofer to the main board and disconnect the connector attaching them.
      • Your subwoofer is now disconnected and ready to be replaced.
      Ask FixBot
    1. Amazon Echo Studio Light Board Replacement, Motherboard: step 8, image 1 of 2 Amazon Echo Studio Light Board Replacement, Motherboard: step 8, image 2 of 2
      • Remove the thirteen 9 mm Phillips #00 screws.
      • Some screws may be hidden by other components; simply hold them out of your way during screw removal.
      Ask FixBot
    2. Amazon Echo Studio Light Board Replacement: step 9, image 1 of 1
      • Unfasten the Phillips 9mm screws, using the Phillips #00 Screwdriver.
      • There may be obstruction against some screws, which can be avoided by using a spudger or your hand.
      Ask FixBot
    3. Amazon Echo Studio Light Board Replacement: step 10, image 1 of 3 Amazon Echo Studio Light Board Replacement: step 10, image 2 of 3 Amazon Echo Studio Light Board Replacement: step 10, image 3 of 3
      • After removing the screws, locate the four power connectors on the motherboard and detach them from the motherboard.
      Ask FixBot
    4. Amazon Echo Studio Light Board Replacement: step 11, image 1 of 1
      • Remove the motherboard from the device by pulling it out.
      • Be careful to not damage any of the loose wires inside the case while removing the motherboard.
      Ask FixBot
    1. Amazon Echo Studio Light Board Replacement, Light Board: step 12, image 1 of 3 Amazon Echo Studio Light Board Replacement, Light Board: step 12, image 2 of 3 Amazon Echo Studio Light Board Replacement, Light Board: step 12, image 3 of 3
      • First, locate the six 10 mm screws at the top of the inside of the shell and unscrew them with a T10 Torx screwdriver.
      • After removing the six screws from the inside, lift the top speaker cover.
      Ask FixBot
    2. Amazon Echo Studio Light Board Replacement: step 13, image 1 of 3 Amazon Echo Studio Light Board Replacement: step 13, image 2 of 3 Amazon Echo Studio Light Board Replacement: step 13, image 3 of 3
      • Lift the top plastic cover that has the buttons.
      • If you feel a lot of resistance while removing this piece, check if you removed every screw from the inside or you risk breaking this part.
      Ask FixBot
    3. Amazon Echo Studio Light Board Replacement: step 14, image 1 of 3 Amazon Echo Studio Light Board Replacement: step 14, image 2 of 3 Amazon Echo Studio Light Board Replacement: step 14, image 3 of 3
      • After the screws are removed, carefully lift the lightboard and disconnect the ribbon.
      • Make sure you do not forget to detach the ribbon from the shell, or you risk breaking it.
      Ask FixBot
Filipe Oliveira
339 Reputation
2 Guides authored
UMass Dartmouth, Team 2-6, Petersen Fall 2022 Member of UMass Dartmouth, Team 2-6, Petersen Fall 2022
UMASSD-PETERSEN-F22S2G6
4 Members
72 Guides authored
1 Guide Comment
Where can I find a replacement light board?
Ralph - Reply Share
Past 24 Hours: 3
Past 7 Days: 20
Past 30 Days: 80
All Time: 1,231
