Amazon Echo Show 8 2nd Generation Camera Replacement
  1. Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: step 1, image 1 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: step 1, image 2 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement, Rear Case: step 1, image 3 of 3
    • Flip the device so that the rubber foot is facing up.
    • Insert a Jimmy between the rubber foot and chassis, then slide it around the perimeter until the rubber foot releases.
    • The adhesive that holds the rubber mat on may require some force to sever.
    • Remove the rubber foot.
  2. Amazon Echo Show 8 2nd Generation Camera Replacement: step 2, image 1 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 2, image 2 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 2, image 3 of 3
    • Use a T6 Torx screwdriver to remove the five 4.5 mm screws from the base of the device.
  3. Amazon Echo Show 8 2nd Generation Camera Replacement: step 3, image 1 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 3, image 2 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 3, image 3 of 3
    • Insert a Jimmy in the gap between the front and rear case.
    • Work the Jimmy around the perimeter to gently detach the rear case from the front case.
    • Separate the rear case from the front case.
    • There are 2 thin ribbon cables connecting the microphone board to the back cover. Take care not to tear or strain them as you separate the cases.
  4. Amazon Echo Show 8 2nd Generation Camera Replacement: step 4, image 1 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 4, image 2 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 4, image 3 of 3
    • Use a T6 Torx screwdriver to remove the four 5.2 mm screws that secure the microphone board to the rear case.
  5. Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: step 5, image 1 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: step 5, image 2 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement, Camera: step 5, image 3 of 3
    • Use a T6 Torx screwdriver to remove the six 7.6 mm screws that secure the speaker housing to the screen assembly.
    • There is a screw that is not pictured in the center of the bottom two screws.
  6. Amazon Echo Show 8 2nd Generation Camera Replacement: step 6, image 1 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 6, image 2 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 6, image 3 of 3
    • Gently separate the speaker housing from the display assembly and set the device on a flat surface.
    • There is a cable connecting the speaker housing to the display assembly. Take care not to pull on it while separating the two parts.
    • Use a plastic spudger to pry up and remove the foam mat at the center of the silver bracket.
  7. Amazon Echo Show 8 2nd Generation Camera Replacement: step 7, image 1 of 2 Amazon Echo Show 8 2nd Generation Camera Replacement: step 7, image 2 of 2
    • Use a T6 Torx screwdriver to remove the eleven 6 mm screws that secure the silver bracket.
  8. Amazon Echo Show 8 2nd Generation Camera Replacement: step 8, image 1 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 8, image 2 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 8, image 3 of 3
    • Use a plastic spudger to lift up the remove the silver bracket.
    • The camera is located to the left of the mother board.
  9. Amazon Echo Show 8 2nd Generation Camera Replacement: step 9, image 1 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 9, image 2 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 9, image 3 of 3
    • Use a T6 Torx screwdriver to remove the two 6 mm screws that secure the camera retention plate.
  10. Amazon Echo Show 8 2nd Generation Camera Replacement: step 10, image 1 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 10, image 2 of 3 Amazon Echo Show 8 2nd Generation Camera Replacement: step 10, image 3 of 3
    • Use a spudger to slightly lift the camera retention plate.
    • Lift the camera retention plate up and out of the chassis.
  11. Amazon Echo Show 8 2nd Generation Camera Replacement: step 11, image 1 of 2 Amazon Echo Show 8 2nd Generation Camera Replacement: step 11, image 2 of 2
    • Use the pointed end of a spudger to flip up the camera ribbon cable ZIF locking flap.
    • Pull the ribbon cable directly out of its socket.
  12. Amazon Echo Show 8 2nd Generation Camera Replacement: step 12, image 1 of 2 Amazon Echo Show 8 2nd Generation Camera Replacement: step 12, image 2 of 2
    • Lift up the camera gently, and use the pointed end of the spudger to gently remove the thin black ribbon cable.
    • The thin tab holding is held down with adhesive. Be gentle when removing it to prevent tearing it.
Brian Le
681 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 28
All Time: 387
