Amazon Echo Show 5-Megapixel Camera Replacement
  1. Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: step 1, image 1 of 2 Amazon Echo Show 5-Megapixel Camera  Replacement, Camera: step 1, image 2 of 2
    • Use the plastic opening tool to gently lift the plastic protector from the screen.
  2. Amazon Echo Show 5-Megapixel Camera  Replacement: step 2, image 1 of 2 Amazon Echo Show 5-Megapixel Camera  Replacement: step 2, image 2 of 2
    • After the protector has been removed, use your hands to gently remove the taped-in rubber foot from device.
  3. Amazon Echo Show 5-Megapixel Camera  Replacement: step 3, image 1 of 1
    • Carefully peel off the bottom pad to expose the fastening screws.
    • Remove three silver 1.4 T5 Torx screws on the top row.
    • Remove one green 1mm T5 Torx screw in the middle.
    • Remove a black 1.5mm T5 screw.
    • Remove three green 1mm T5 screws from the bottom row.
  4. Amazon Echo Show 5-Megapixel Camera  Replacement: step 4, image 1 of 3 Amazon Echo Show 5-Megapixel Camera  Replacement: step 4, image 2 of 3 Amazon Echo Show 5-Megapixel Camera  Replacement: step 4, image 3 of 3
    • After the screws are removed, grip the front panel and separate the front from the back. This will expose the inside of the device.
    • Make sure to ground yourself against a metal object nearby (ex. a metal chair, a door frame) before you touch any circuitry. An accidental static discharge can permanently damage a circuitboard.
    • Use tweezers or your hands to carefully disconnect the red wires connecting the speakers to the power supply board.
    • Lay the front section flat, with the screen down.
  5. Amazon Echo Show 5-Megapixel Camera  Replacement: step 5, image 1 of 3 Amazon Echo Show 5-Megapixel Camera  Replacement: step 5, image 2 of 3 Amazon Echo Show 5-Megapixel Camera  Replacement: step 5, image 3 of 3
    • Remove two 1mm T5 Torx screws.
    • Once the screws have been removed, you can easily remove the camera from the device.
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 15
All Time: 2,142
