Amazon Echo Glow Power Cable Replacement
    1. Amazon Echo Glow Power Cable Replacement, Motherboard: step 1, image 1 of 2 Amazon Echo Glow Power Cable Replacement, Motherboard: step 1, image 2 of 2
      • Unplug the device from any outlets to ensure that the device is completely powered off while disassembling the device.
      • Using the metal spudger, insert it into the seam between the outer shell and the base of the Amazon Echo Glow. Break open the glued seal that holds the outer shell to get into the device.
      • This step requires a bit of force to cut through the factory seal adhesive glue.
      Ask FixBot
    2. Amazon Echo Glow Power Cable Replacement: step 2, image 1 of 2 Amazon Echo Glow Power Cable Replacement: step 2, image 2 of 2
      • Work the metal spudger through the seam all the way around the device until the outer shell is completely loose from the base of the device.
      Ask FixBot
    3. Amazon Echo Glow Power Cable Replacement: step 3, image 1 of 3 Amazon Echo Glow Power Cable Replacement: step 3, image 2 of 3 Amazon Echo Glow Power Cable Replacement: step 3, image 3 of 3
      • Fully remove the outer shell from the Amazon Echo Glow.
      • This will expose the motherboard. Be sure that the device is completely powered off before proceeding.
      Ask FixBot
    4. Amazon Echo Glow Power Cable Replacement: step 4, image 1 of 3 Amazon Echo Glow Power Cable Replacement: step 4, image 2 of 3 Amazon Echo Glow Power Cable Replacement: step 4, image 3 of 3
      • Use a Phillips screwdriver to remove the five screws securing the motherboard.
      Ask FixBot
    5. Amazon Echo Glow Power Cable Replacement: step 5, image 1 of 3 Amazon Echo Glow Power Cable Replacement: step 5, image 2 of 3 Amazon Echo Glow Power Cable Replacement: step 5, image 3 of 3
      • Use the tweezers to remove the red and black cable connector from the motherboard.
      • Remove the motherboard.
      Ask FixBot
    1. Amazon Echo Glow Power Cable Replacement, Internal Bracket: step 6, image 1 of 3 Amazon Echo Glow Power Cable Replacement, Internal Bracket: step 6, image 2 of 3 Amazon Echo Glow Power Cable Replacement, Internal Bracket: step 6, image 3 of 3
      • Use s T10 Torx screwdriver to remove the four screws securing the bracket.
      Ask FixBot
    2. Amazon Echo Glow Power Cable Replacement: step 7, image 1 of 3 Amazon Echo Glow Power Cable Replacement: step 7, image 2 of 3 Amazon Echo Glow Power Cable Replacement: step 7, image 3 of 3
      • Carefully lift and remove the bracket.
      Ask FixBot
    1. Amazon Echo Glow Power Cable Replacement, Power Cable: step 8, image 1 of 1
      • Pull the power cable through the shell to remove it from the device.
      Ask FixBot
  • Reseal the device by using hot glue around the seam of the outer shell.
John Aguilar
243 Reputation
2 Guides authored
Texas Tech, Team 8-1, Johansen Spring 2026 Member of Texas Tech, Team 8-1, Johansen Spring 2026
TTU-JOHANSEN-S26S8G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 10
Past 30 Days: 52
All Time: 133
