Amazon Echo Glow Action Button Replacement
    1. Amazon Echo Glow Action Button Replacement, Action Button: step 1, image 1 of 3 Amazon Echo Glow Action Button Replacement, Action Button: step 1, image 2 of 3 Amazon Echo Glow Action Button Replacement, Action Button: step 1, image 3 of 3
      • Using the metal spudger, cut through the glue that is in the seam between the outer shell and the base of the device.
      • Work the metal spudger through the seam all the way around the device until the outer shell is completely loose from the base of the device.
      • You will need to apply adhesive glue to the seam when reassembling the device.
      • Remove the outer shell from the base of the device.
      Ask FixBot
    2. Amazon Echo Glow Action Button Replacement: step 2, image 1 of 3 Amazon Echo Glow Action Button Replacement: step 2, image 2 of 3 Amazon Echo Glow Action Button Replacement: step 2, image 3 of 3
      • Remove the five Phillips screws securing the motherboard.
      Ask FixBot
    3. Amazon Echo Glow Action Button Replacement: step 3, image 1 of 3 Amazon Echo Glow Action Button Replacement: step 3, image 2 of 3 Amazon Echo Glow Action Button Replacement: step 3, image 3 of 3
      • Slightly lift the motherboard from the device. Do not fully remove, you still need to detach the red and black cables from the motherboard.
      • Using your fingers or tweezers, carefully hold the connector itself and remove the red and black cable connector from the motherboard.
      Ask FixBot
    4. Amazon Echo Glow Action Button Replacement: step 4, image 1 of 3 Amazon Echo Glow Action Button Replacement: step 4, image 2 of 3 Amazon Echo Glow Action Button Replacement: step 4, image 3 of 3
      • Remove the four the T10 Torx screws securing the bracket.
      • Remove the bracket.
      Ask FixBot
    5. Amazon Echo Glow Action Button Replacement: step 5, image 1 of 3 Amazon Echo Glow Action Button Replacement: step 5, image 2 of 3 Amazon Echo Glow Action Button Replacement: step 5, image 3 of 3
      • The bracket is removed from the device, you will then need to pull the red and black cables out from the device to ensure they won't be damaged.
      • There are two points that connect the button and the device together, you will need to cut through those two points with the metal spudger to remove the defective button from the device.
      Ask FixBot
    6. Amazon Echo Glow Action Button Replacement: step 6, image 1 of 2 Amazon Echo Glow Action Button Replacement: step 6, image 2 of 2
      • Remove the defective action button with tweezers, once you have completed cutting through the two connectives points.
      • Now the button is removed apply adhesive glue to the new button at the same two points that they were previously connected to.
      • Allow for proper time for the adhesive glue to dry.
      Ask FixBot
Tim Trevino
133 Reputation
1 Guide authored
Texas Tech, Team 8-1, Johansen Spring 2026 Member of Texas Tech, Team 8-1, Johansen Spring 2026
TTU-JOHANSEN-S26S8G1
4 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 7
Past 30 Days: 34
All Time: 114
