This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
Altyk le Petit PC RAM Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
82
All Time:
411
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 minutes
Difficulty: Easy
Community-Contributed Guide
Missing Details
Some of this guide's details are missing. Help users by adding tools, difficulty, or time.
Introduction
Go to step 1 ↓
RAM replacement on the Altyk le Petit PC
Tools
    1. Altyk le Petit PC RAM Replacement, Locating the opening screws: step 1, image 1 of 1
      • First, disconnect your machine from the power supply, then turn it over and locate the 4 screws in the 4 corners under the machine. These are Phillips screws, and you will need a Phillips screwdriver with a long shaft.
      Ask FixBot
    2. Altyk le Petit PC RAM Replacement, Opening the machine: step 2, image 1 of 2 Altyk le Petit PC RAM Replacement, Opening the machine: step 2, image 2 of 2
      • Locate the small notch between the two Ethernet ports on the top. Use your fingernail or an opening pick to pry up and lift the machine's cover.
      Ask FixBot
    3. Altyk le Petit PC RAM Replacement, Remove the SSD/RAM cooling system: step 3, image 1 of 2 Altyk le Petit PC RAM Replacement, Remove the SSD/RAM cooling system: step 3, image 2 of 2
      • Lift the SSD and RAM active cooling system by grabbing it from a corner, so you can reveal the cooling fan connector and disconnect it.
      Ask FixBot
    4. Altyk le Petit PC RAM Replacement, Replace the RAM: step 4, image 1 of 1
      • You now have access to the RAM. It is a 16GB DDR4 SODIMM 3200MHz RAM stick, you can now replace it.
      • Once the RAM stick is replaced, you can reassemble your machine.
      Ask FixBot
To reassemble your device, follow the instructions in reverse order.
INFOREA
4,981 Reputation
47 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 82
All Time: 411
