Alldaymall A88X Back Cover
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
    1. Alldaymall A88X Back Cover, Alldaymall A88X Back Cover: step 1, image 1 of 3 Alldaymall A88X Back Cover, Alldaymall A88X Back Cover: step 1, image 2 of 3 Alldaymall A88X Back Cover, Alldaymall A88X Back Cover: step 1, image 3 of 3
      • Using a plastic opening tool, carefully pry the device apart. Make your way around the entire perimeter of the device and carefully place the two panels next to each other.
      • After the panels are separated, watch out for the speaker on the rear panel as it's wire is rather short.
      • When separating the panels keep an eye out for the power button and volume rocker as they can be dislodged.
      Ask FixBot
    2. Alldaymall A88X Back Cover: step 2, image 1 of 1
      Tool used on this step:
      Buy
      • Grip the speaker from the sides with your fingers or a pair of tweezers and slowly begin to remove it from the rear panel.
      • When removing the speaker, make sure not to disconnect the wires in any way.
      • After the speaker has been removed, place the rear panel aside.
      Ask FixBot
Drhaber
985 Reputation
7 Guides authored
USF Tampa, Team 4-1, Lacy Spring 2016 Member of USF Tampa, Team 4-1, Lacy Spring 2016
USFT-LACY-S16S4G1
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 11
All Time: 213
