Fix Your Stuff
Right to Repair
Store
You're viewing a previously published version of this guide.  View latest version
Older Newer
Introduction
In this guide, we will show you how to remove and replace the Hard-Drive.
  1. WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • Turn the computer over.
  2. Slide the battery latch to the unlock position as shown.
    • Slide the battery latch to the unlock position as shown.
  3. After the Battery Pack pops up, remove the Battery Pack.
    • After the Battery Pack pops up, remove the Battery Pack.
  4. Align the battery pack tabs with the slots in the battery bay.
    • Align the battery pack tabs with the slots in the battery bay.
  5. Push the NEW battery pack into the battery bay until the battery pack clicks into place.
    • Push the NEW battery pack into the battery bay until the battery pack clicks into place.
  6. WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • WARNING: If you remove the hard drive from the computer when the drive is hot, do not touch the metal housing of the hard drive.
    • Loosen the four captive screws that secure the hard-drive assembly.
  7. Using the pull-tab, lift the hard-drive assembly out of the hard-drive bay.
    • Using the pull-tab, lift the hard-drive assembly out of the hard-drive bay.
  8. Remove the four screws that secure the hard drive to the hard-drive bracket.
    • Remove the four screws that secure the hard drive to the hard-drive bracket.
  9. Lift the hard drive out of the hard-drive bracket. Lift the hard drive out of the hard-drive bracket.
    • Lift the hard drive out of the hard-drive bracket.
  10. Disconnect the interposer from the hard drive. Disconnect the interposer from the hard drive.
    • Disconnect the interposer from the hard drive.
  11. Connect the interposer to the NEW hard drive. Connect the interposer to the NEW hard drive.
    • Connect the interposer to the NEW hard drive.
  12. Place the hard drive in the hard-drive bracket. Place the hard drive in the hard-drive bracket.
    • Place the hard drive in the hard-drive bracket.
  13. Replace the four screws that secure the hard drive to the hard-drive bracket.
    • Replace the four screws that secure the hard drive to the hard-drive bracket.
  14. Place the hard-drive assembly in the hard-drive bay.
    • Place the hard-drive assembly in the hard-drive bay.
  15. Align and tighten the four captive screws that secure the hard-drive assembly to the hard-drive bay.
    • Align and tighten the four captive screws that secure the hard-drive assembly to the hard-drive bay.
Terrence15
72,456 Reputation
442 Guides authored
Informative Technologies Inc. Member of Informative Technologies Inc.
Community
21 Members
1,824 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 255
