Shop the Holiday Gift Guide
Alienware M15x Display Assembly Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
All Time:
93
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 30 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, we will show you how to remove and replace the Display Assembly.
Tools
    1. Alienware M15x Display Assembly Replacement, Remove the Two Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on the back of the computer).
      • Remove the two screws from the battery bay.
      Ask FixBot
    2. Alienware M15x Display Assembly Replacement, Turn the Computer Up: step 2, image 1 of 1
      • Turn the computer top side up and open the display as far as possible.
      Ask FixBot
    3. Alienware M15x Display Assembly Replacement, Disconnect the Cables: step 3, image 1 of 1
      • Disconnect the antenna cables from the respective Mini-Cards and remove these cables from their routing guides.
      Ask FixBot
    4. Alienware M15x Display Assembly Replacement, Disconnecting the Display Cable: step 4, image 1 of 1
      • Disconnect the display cable and the camera cable from the respective 12. system board connectors, and remove these cables from their routing guides.
      Ask FixBot
    5. Alienware M15x Display Assembly Replacement, Remove the Four Screws: step 5, image 1 of 1
      • Remove the four screws (two from each hinge) that secure the display assembly to the computer base.
      Ask FixBot
    6. Alienware M15x Display Assembly Replacement, Tilting the Display Assembly: step 6, image 1 of 1
      • Tilt the display assembly towards the computer base at a 45-degree angle and lift the display assembly off the computer.
      Ask FixBot
    7. Alienware M15x Display Assembly Replacement, Align the Screw Holes: step 7, image 1 of 1
      • Align the screw holes on the display hinges with the screw holes on the computer base.
      Ask FixBot
    8. Alienware M15x Display Assembly Replacement, Routing the Antenna Cables: step 8, image 1 of 1
      • Route the Mini-Card antenna cables through the routing guides and connect them to the respective Mini-Cards.
      Ask FixBot
    9. Alienware M15x Display Assembly Replacement, Route the Display and Camera Cables: step 9, image 1 of 1
      • Route the display and camera cables through the routing guides and connect them to the system board connectors.
      Ask FixBot
    10. Alienware M15x Display Assembly Replacement, Replace the Two Screws: step 10, image 1 of 1
      • Replace the two screws in the battery bay.
      Ask FixBot
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 1
All Time: 93
