Shop the Holiday Gift Guide
Alienware M11xR2 Memory Modules Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
0
Past 30 Days:
All Time:
156
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 - 8 minutes
Difficulty: Easy
Prerequisite Only
This is a prerequisite-only guide! This guide is part of another procedure and isn’t meant to be used alone.
Community-Contributed Guide
Introduction
Go to step 1 ↓
In this guide, we will be showing you how to remove and replace the Memory Modules.
Tools
    1. Alienware M11xR2 Memory Modules Replacement, Removing Screws: step 1, image 1 of 1
      • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer)
      • Remove the two screws that secure the battery pack to the computer base.
      Ask FixBot
    2. Alienware M11xR2 Memory Modules Replacement, Disconnecting cable: step 2, image 1 of 1
      • Disconnect the battery pack cable from the connector on the system board.
      Ask FixBot
    3. Alienware M11xR2 Memory Modules Replacement, Lifting Battery Pack: step 3, image 1 of 1
      • Using the pull-tab, lift the battery pack off the computer base.
      Ask FixBot
    4. Alienware M11xR2 Memory Modules Replacement, Placing New Battery Pack: step 4, image 1 of 1
      • Place the NEW battery pack in the battery bay and replace the two screws that secure the battery pack to the computer base.
      Ask FixBot
    5. Alienware M11xR2 Memory Modules Replacement, Routing Battery Pack: step 5, image 1 of 1
      • Route the battery pack cable in the routing guide
      Ask FixBot
    6. Alienware M11xR2 Memory Modules Replacement, Connnecting Battery Pack: step 6, image 1 of 1
      • Connect the battery pack cable to the connector on the system board.
      Ask FixBot
    1. Alienware M11xR2 Memory Modules Replacement, Popping up the Memory Module: step 7, image 1 of 3 Alienware M11xR2 Memory Modules Replacement, Popping up the Memory Module: step 7, image 2 of 3 Alienware M11xR2 Memory Modules Replacement, Popping up the Memory Module: step 7, image 3 of 3
      • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
      • CAUTION: To prevent damage to the memory-module connector, do not use tools to spread the memory module securing clips.1memory-module connector2securing clips (2) 3memory moduleNOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
      • Use your fingertips to carefully spread apart the securing clips on each end of the memory-module connector until the memory module pops up.
      Ask FixBot
    2. Alienware M11xR2 Memory Modules Replacement, Align the Notch: step 8, image 1 of 3 Alienware M11xR2 Memory Modules Replacement, Align the Notch: step 8, image 2 of 3 Alienware M11xR2 Memory Modules Replacement, Align the Notch: step 8, image 3 of 3
      • NOTE: If you need to install memory modules in two connectors, install a memory module in the lower connector before you install a memory module in the upper connector.
      • Align the notch in the NEW memory module with the tab in the memory-module connector.
      Ask FixBot
    3. Alienware M11xR2 Memory Modules Replacement, Securing the Memory Module: step 9, image 1 of 2 Alienware M11xR2 Memory Modules Replacement, Securing the Memory Module: step 9, image 2 of 2
      • Slide the memory module firmly into the connector at a 45-degree angle, and press the memory module down until it clicks into place. If you do not hear the click, remove the memory module and reinstall it.
      • NOTE: If the memory module is not installed properly, the computer may not boot.
      Ask FixBot
Author
with
Terrence15
80,173 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
12,349 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 156
