Alienware M11xR2 Coin-Cell Battery Replacement
  1. Alienware M11xR2 Coin-Cell Battery Replacement, Removing the Base Cover: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer.
    • CAUTION: To avoid electrostatic discharge, ground yourself by using a wrist grounding strap or by periodically touching an unpainted metal surface (such as a connector on your computer).
    • Turn the computer over.
  2. Alienware M11xR2 Coin-Cell Battery Replacement, Loosen the Screws: step 2, image 1 of 1
    • Loosen the eight captive screws that secure the base cover to the computer base.
  3. Alienware M11xR2 Coin-Cell Battery Replacement, Lifting the Base Cover: step 3, image 1 of 1
    • Lift the base cover off the computer base.
  4. Alienware M11xR2 Coin-Cell Battery Replacement, Replacing the Base Cover: step 4, image 1 of 1
    • Align the tabs on the NEW base cover with the slots on the computer base and place the base cover in position.
  5. Alienware M11xR2 Coin-Cell Battery Replacement, Securing the Screws: step 5, image 1 of 1
    • Tighten the eight screws that secure the base cover to the computer base.
  6. Alienware M11xR2 Coin-Cell Battery Replacement, Disconnecting Coin-Cell Battery: step 6, image 1 of 1
    • Disconnect the coin-cell battery cable from the connector on the system board.
  7. Alienware M11xR2 Coin-Cell Battery Replacement, Prying The Coin-Cell Battery: step 7, image 1 of 1
    • The coin-cell battery is glued to the system board. Using a plastic scribe, pry the coin-cell battery from the system board.
  8. Alienware M11xR2 Coin-Cell Battery Replacement, Placing New Coin-Cell Battery: step 8, image 1 of 1
    • Use the adhesive on NEW the coin-cell battery and adhere it to the system board.
  9. Alienware M11xR2 Coin-Cell Battery Replacement, Connecting Cable: step 9, image 1 of 1
    • Connect the coin-cell battery cable to the connector on the system board.
darrius
5,213 Reputation
30 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,985 Guides authored
Past 24 Hours: 2
Past 7 Days: 9
Past 30 Days: 13
All Time: 413
