Alienware AW510H Motherboard Replacement
  1. Alienware AW510H Motherboard Replacement, Earpad Cushions: step 1, image 1 of 1
    • Hold the earcup with one hand and firmly grip the ear pad with the other.
  2. Alienware AW510H Motherboard Replacement: step 2, image 1 of 3 Alienware AW510H Motherboard Replacement: step 2, image 2 of 3 Alienware AW510H Motherboard Replacement: step 2, image 3 of 3
    • Rotate the earcup counter-clockwise before pulling it away from the headset.
  3. Alienware AW510H Motherboard Replacement, Microphone Assembly: step 3, image 1 of 2 Alienware AW510H Motherboard Replacement, Microphone Assembly: step 3, image 2 of 2
    • Remove the four 8.5mm screws found on the base of the ear cup housing using a Phillips #0 screwdriver.
  4. Alienware AW510H Motherboard Replacement: step 4, image 1 of 1
    • Gently remove the plastic shell.
  5. Alienware AW510H Motherboard Replacement: step 5, image 1 of 1
    • Remove the 5mm screw from the microphone cover using a Phillips #1 screwdriver.
    • Follow the microphone boom connection to the driver and motherboard.
    • The microphone is located on the left side, retractable and bendable.
  6. Alienware AW510H Motherboard Replacement: step 6, image 1 of 1
    • If there is a protective plastic or glue coating on top of the solder, scrape it off using a metal spudger before soldering.
  7. Alienware AW510H Motherboard Replacement: step 7, image 1 of 1
    • Use a soldering iron to disconnect the wire connecting the microphone to the motherboard.
  8. Alienware AW510H Motherboard Replacement: step 8, image 1 of 3 Alienware AW510H Motherboard Replacement: step 8, image 2 of 3 Alienware AW510H Motherboard Replacement: step 8, image 3 of 3
    • Pull the old microphone assembly out of the housing.
    • If the mechanism is stuck inside, gently push it out from inside the housing, perhaps with the help of tweezers or small needle nose pliers.
  9. Alienware AW510H Motherboard Replacement, Motherboard: step 9, image 1 of 3 Alienware AW510H Motherboard Replacement, Motherboard: step 9, image 2 of 3 Alienware AW510H Motherboard Replacement, Motherboard: step 9, image 3 of 3
    • Desolder the motherboard from the driver casing.
    • Remember to follow safety precautions for soldering.
devant brooks
123 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 15
Past 30 Days: 15
All Time: 111
