Alienware AW510H Microphone Assembly Replacement
    1. Alienware AW510H Microphone Assembly Replacement, Earpad Cushions: step 1, image 1 of 1
      • Hold the earcup with one hand and firmly grip the ear pad with the other.
      Ask FixBot
    2. Alienware AW510H Microphone Assembly Replacement: step 2, image 1 of 3 Alienware AW510H Microphone Assembly Replacement: step 2, image 2 of 3 Alienware AW510H Microphone Assembly Replacement: step 2, image 3 of 3
      • Rotate the earcup counter-clockwise before pulling it away from the headset.
      Ask FixBot
    1. Alienware AW510H Microphone Assembly Replacement, Microphone Assembly: step 3, image 1 of 2 Alienware AW510H Microphone Assembly Replacement, Microphone Assembly: step 3, image 2 of 2
      • Remove the four 8.5mm screws found on the base of the left ear cup housing using a Phillips #0 screwdriver.
      Ask FixBot
    2. Alienware AW510H Microphone Assembly Replacement: step 4, image 1 of 1
      • Gently lift the plastic shell, being cautious of the wire that is still attached.
      Ask FixBot
    3. Alienware AW510H Microphone Assembly Replacement: step 5, image 1 of 1
      • Remove the 5mm screw from the microphone cover using a Phillips #1 screwdriver.
      • Follow the microphone boom connection to the driver and motherboard.
      • The retractable and bendable microphone is located on the left side.
      Ask FixBot
    4. Alienware AW510H Microphone Assembly Replacement: step 6, image 1 of 1
      • If there is a protective plastic or glue coating on top of the solder, scrape it off using a metal spudger before desoldering.
      Ask FixBot
    5. Alienware AW510H Microphone Assembly Replacement: step 7, image 1 of 1
      • Use a soldering iron to disconnect the wire connecting the microphone to the motherboard.
      Ask FixBot
    6. Alienware AW510H Microphone Assembly Replacement: step 8, image 1 of 3 Alienware AW510H Microphone Assembly Replacement: step 8, image 2 of 3 Alienware AW510H Microphone Assembly Replacement: step 8, image 3 of 3
      • Pull the old microphone assembly out of the housing.
      • If the mechanism is stuck inside, gently push it out from inside the housing, perhaps with the help of tweezers or small needle nose pliers.
      Ask FixBot
Faiza Hussain
217 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 19
Past 30 Days: 59
All Time: 243
