Alienware 17 R2 Wireless Card Replacement
  1. Alienware 17 R2 Wireless Card Replacement, Removing the Screw: step 1, image 1 of 1
    • WARNING: Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Remove the screw that secures the wireless-card bracket and the wireless card to the system board.
  2. Alienware 17 R2 Wireless Card Replacement, Lifting the Card Bracket: step 2, image 1 of 1
    • Lift the wireless-card bracket off the wireless card.
  3. Alienware 17 R2 Wireless Card Replacement, Disconnecting Antenna Cables: step 3, image 1 of 1
    • Disconnect the antenna cables from the wireless card.
  4. Alienware 17 R2 Wireless Card Replacement, Removing the Wireless Card: step 4, image 1 of 1
    • Lift and slide the wireless card from the wireless-card slot.
    • CAUTION: To avoid damaging the wireless card, do not place any cables under it.
    • Align the notch on the wireless card with the tab on the wireless-card slot.
  5. Alienware 17 R2 Wireless Card Replacement, Sliding the Wireless Card: step 6, image 1 of 1
    • Slide the wireless card at an angle into the wireless-card slot.
  6. Alienware 17 R2 Wireless Card Replacement, Connecting Cables to the Wireless Card: step 7, image 1 of 1
    • Connect the antenna cables to the wireless-card.
    • The following is the antenna-cable color color scheme for the wireless card: Main (white triangle) = White Auxiliary (black triangle) = Black
  7. Alienware 17 R2 Wireless Card Replacement, Aligining the Screw Holes: step 8, image 1 of 1
    • Align the screw hole on the wireless-card bracket with the screw hole on the wireless card.
  8. Alienware 17 R2 Wireless Card Replacement, Replacing the Screw: step 9, image 1 of 1
    • Replace the screw that secures the wireless-card bracket and the wireless card to the system board.
Terrence15
79,161 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
42 Members
1,989 Guides authored
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 17
All Time: 734
