Alienware 17 R2 Keyboard Replacement
  1. Ask FixBot
  2. Alienware 17 R2 Keyboard Replacement, Close the Display: step 2, image 1 of 1
    • Close the display and turn the computer over.
    • Make sure PC is turned off!
    Ask FixBot
  3. Alienware 17 R2 Keyboard Replacement, Loosen Screws: step 3, image 1 of 1
    • Loosen the captive screws that secure the base panel to the computer base.
    Ask FixBot
  4. Alienware 17 R2 Keyboard Replacement, Releasing Tabs: step 4, image 1 of 1
    • Using a plastic scribe, gently release the tabs that secure the base panel to the computer base.
    Ask FixBot
  5. Alienware 17 R2 Keyboard Replacement, Remove Base Panel: step 5, image 1 of 1
    • Slide and remove the base panel from the computer base.
    Ask FixBot
  6. Alienware 17 R2 Keyboard Replacement, Disconnect Battery Cable: step 6, image 1 of 1
    • Disconnect the Battery cable from the system board.
    Ask FixBot
    • Turn the computer over.
    Ask FixBot
    • Press and hold power button for 5 seconds to ground the system board.
    Ask FixBot
  7. Alienware 17 R2 Keyboard Replacement, Battery Cable: step 9, image 1 of 1
    • Connect the battery cable to the system board.
    Ask FixBot
  8. Alienware 17 R2 Keyboard Replacement, Tighten Screws: step 10, image 1 of 1
    • Tighten the captive screws that secure the base panel to the computer base.
    Ask FixBot
    • WARNING : Before working inside your computer, read the safety information that shipped with your computer and follow the steps in Before Working Inside Your Computer. After working inside your computer, follow the instructions in After Working Inside Your Computer.
    • Make sure the base panel is removed.
    • Make sure palm rest is removed.
    • Lift the latches and disconnect the touch-pad cable and the status-light cable from the power-button board.
    Ask FixBot
  9. Alienware 17 R2 Keyboard Replacement, Peel off the Cables: step 12, image 1 of 1
    • Note the touch-pad cable and status-light cable routing and peel off the cables from the keyboard bracket.
    Ask FixBot
  10. Alienware 17 R2 Keyboard Replacement, Screw Removal: step 13, image 1 of 1
    • Remove the screws that secure the keyboard bracket to the palm-rest assembly.
    Ask FixBot
    • Slide the keyboard cable, keyboard-backlight cable, macro-keys cable and macro-keys backlight cable through the slot on the keyboard bracket.
    Ask FixBot
  11. Alienware 17 R2 Keyboard Replacement, Lifting the Keyboard Bracket: step 15, image 1 of 1
    • Lift the keyboard bracket off the palm-rest assembly.
    Ask FixBot
  12. Alienware 17 R2 Keyboard Replacement: step 16, image 1 of 1
    • Remove the screws that secure the keyboard to the palm rest assembly.
    Ask FixBot
  13. Alienware 17 R2 Keyboard Replacement, Releasing the Tabs: step 17, image 1 of 1
    • Release the tabs that secure the keyboard to the palm-rest assembly.
    Ask FixBot
  14. Alienware 17 R2 Keyboard Replacement, Lifting the Keyboard: step 18, image 1 of 1
    • Slide and lift the keyboard along with the cables off the palm-rest assembly.
    Ask FixBot
    • Slide the new keyboard under the tabs on the palm-rest assembly.
    Ask FixBot
  15. Alienware 17 R2 Keyboard Replacement, Screw Alignment: step 20, image 1 of 1
    • Align the screw holes on the keyboard with the screw holes on the palm-rest assembly.
    Ask FixBot
    • Replace the screws that secure the keyboard to the palm-rest assembly.
    Ask FixBot
    • Route the keyboard cable, keyboard-backlight cable, marco-keys cable and marco-keys backlight cable through the slots on the keyboard bracket.
    Ask FixBot
    • Align the screw holes on the keyboard bracket with the screw holes on the palm-rest assembly.
    Ask FixBot
  16. Alienware 17 R2 Keyboard Replacement, Replace the Screws: step 24, image 1 of 1
    • Replace the screws that secure the keyboard bracket to the palm-rest assembly.
    Ask FixBot
    • Adhere the touch-pad cable and status-light cable to the keyboard bracket.
    Ask FixBot
    • Slide the touch-pad cable and the status-light cable into their respective connectors on the power-button board and press down the latches to secure the cables.
    Ask FixBot
Terrence15
80,125 Reputation
441 Guides authored
RampUP America, Inc. Member of RampUP America, Inc.
Community
45 Members
2,003 Guides authored
1 Guide Comment
I find it concerning that this guide has you disconnect and reconnect the battery prior to doing anything with the keyboard.
Sean Hanson - Reply Share
Past 24 Hours: 3
Past 7 Days: 39
Past 30 Days: 80
All Time: 2,823
